CNC parallel/breakout question...macona, et al
  • #31
    Where having computer control really shines is when you have a spindle sensor so you can close the loop for spindle speed. Then mach know how fast the spindle is turning and will adjust the motor speed to keep it constant. So when you are under a load it gives the motor more power to keep it there.
