gear box
  • gear box
    I need to make a reverse drive gear box for my snow blower, in a quandary as to type should I use 2 gears, or 3 sprockets and chain. Had a quote for 2 gears and almost died $2,800.00, the gears I had quoted were 10 pitch 20 and 40 tooth 1" thick 3/4" bore, any body know where I can get cheaper gears.
    Gears
    Try www.bostongear.com
      You could make 'em..
      No good deed goes unpunished.
        These are in the ballpark...
        http://cgi.ebay.com/14-1-2-dgr-PRESS...item23089a3616
        http://cgi.ebay.com/14-1-2-dgr-PRESS...item2308729000
        Have fun! Sidegrinder
          Almost to your specification:
          You would have to bush the 40 tooth gear.
          http://www.mcmaster.com/#6867k82/=8oomtc
          20T, 1" face, 3/4" bore. Stock #6867K75 $46.23
          40T, 1" face, 7/8" bore. Stock #6867K82 $91.63
          These are for finished bores (keyway and set screw). Prices are about a third cheaper if you get plain bores.
            You are going to make a snow sucker?
            I know, blow is only an expression.
            "the ocean is the ultimate solution"
              With the number of snowblowers on Craigslist, why not just buy one?
              gvasale
                Where is the fun in that?
                  gear box
                  Well I have the blower already and you don't find many 48" 2 stage that mount on the front of my Kubota, well it didn't fit when I got it but it does now, ran it hydraulically last year but too much slippage and heat build up even when its 10°F outside. Have a center PTO that can run up to 2,000RPM thats why I need a gear box and the PTO turns the wrong direction.
