generator problem
  • generator problem
    My brother in law bring me a Chinese 1500 watt 110v generator
    the voltave regulator is burned out. (the curved piece bolted at the end of the generator 2 wires on a plug black and white 4 wires on the second plug)
    His is rated 110V. I only find 220v. what happen if i put a 220 volt
    By the way tres an other solution to fix it
    Originally posted by Luke55 (edited Liger Zero)
    My brother in law bring me a Chinese 1500 watt 110v generator the voltage regulator is burned out. (the curved piece bolted at the end of the generator 2 wires on a plug black and white 4 wires on the second plug)
    By the way is there another solution to fix it?
    I assume you get 220 volts out of it rather than 110.
    Someone will be along shortly to assist further. If we could get a picture of the broken part showing any part numbers, symbols or marking we will be able to help you locate a part easier.
    Plastic Operators Dot Com
