how do you use small taps?
  • how do you use small taps?
    I have to tap 6 8NC32 holes, about 3/4" deep. My tap broke three times and I had to extract the broken fragment twice with a dremel (I've interest in removal the third time). I was tapping in the small drill-press with the spring of the spindle completely dis-engaged (the one that pulls the spindle up). I was going real slow and backing out the chips every 1/4 turns.
    The tap is CHINESE.
    The tap is CHINESE.
    First off, why would you ever try to tap an 8-32 hole 3/4" deep? The old rule is maximum holding power is attained at 1 1/2 times the diameter of the tap. For an 8-32 that would be something less than 1/4" depth.
    Second off, using Chinese taps for any kind of deep hole tapping is a real mistake.
    Back bore your holes, so that you only have to tap 1/4" deep,and you will be fine.
    I am not young enough to know everything
      Which tap are you using? You need to start the hole and go as far as you can with a taper tap then use a plug tap, the taper tap will cut with much less resistance and is a lot easier to use without breaking. It seems taper taps are hard to find at most stores and usually plug taps are all most places have, some of them do have bottom taps sometimes, but for whatever reason plug types are the most common.
        I use Chinese taps to fill in unwanted holes. Simply crank the sucker in, snap it off and grind flush.
        Seriously... Don't waste your time with that junk. You can follow proper tapping process but it's all for naught if you use junk "Snap-Off(tm)" taps.
        Plastic Operators Dot Com
          How do you back bore a blind hole.... Especially on a hole that small?
            BMSS & Liger are spot on.
              He never said anything about them being a blind holes. Guess you read something that I didn't.
                How do you know if a tap is 'Snap-Off' brand?
                  My pet nickname for junk Chinese tools.
                    I know - but not all taps are advertised as MADE IN USA or something like that
                      If your tapping a hole more than 2x's the diameter in depth the tap drill size can be increased since you will have more threads engaged.The increase in tap drill size means a slightly larger hole and a reduction in the amount of torque required to thread it.
                        To be fair I've had American and French made taps snap off on me. That was mostly my fault as I was still learning how to use them properly. "Cranky Old Machinist In The Corner" showed me the right way... after he bit my head off for ruining his expensive French tap. (I paid to replace it out of my pocket A) because he took the time to teach me the right way and B) that's just how I roll. I break it I replace it.)
                        I had a set of Chinese Taps I got at a flea-market. Complete with Chinese paperwork! They were less than useless for metal I broke most of the smaller diameter ones.
                          They don't have to be made in USA to be good and not all US made taps are good.
                          Some brand names to look for-OSG,Nachi,Greenfield,TRW,TMX,Excello.
                          High Speed steel is best for longevity and for my own personal preference 3 flute taps work best for me when hand tapping,especially spiral point "gun" taps.
                            Why do the chinese tap suck more --- do they start with a weaker metal, or do they get the heat-treatment wrong?
                              Are those brands to watch out for in a negative way? Or as those brand I would want to buy? Do they make taps out of carbide?
