Monarch CBB lathe weight?
  • Monarch CBB lathe weight?
    I have to move this lathe its a 1944 mod CBB lathe 20 inch swing and 96 inches between centers anyone knows the weight of this lathe? Thanks for any and all help Bill.
    You mean like this-
    http://www.midwesternmedicalmachine....onarch_cbb.jpg
    Moved one similar and it ran 5500-6000lbs
      Yes that the one looks the same,,I was thinking about the same weight.
        I would think a little more, my 16 X 54 CY weighs approx 5400 LBS.
        Harry
          Originally posted by beckley23
          I would think a little more, my 16 X 54 CY weighs approx 5400 LBS.Harry
          Me too. I would have figured closer to 8000 pounds. Even if it's not it definitely wouldn't hurt to have some safety factor built in.
          Jonathan P.
            I had a 20x72 CBB. 8 or 9K is about right. Wish I'd kept that lathe, a good one is a pleasure.
              My 13" x 30" Ser.60 Monarch (which really has a 17" swing) is 4600 lb.
              WI/IL border, USA
                My trailer! I was going to use is about 9k max,,may need to rethink this. That's why I was hoping for a close approximate weight with in maybe a few hundred pounds to be sure. If its closer to 7k to 8k i should be fine.
                  You'll work out the moving details.......I'm still green w envy........
                  Opportunity knocks once, temptation leans on the doorbell.....
                    Bill-I've forgotten the catalog weight, mostly going by how it "felt" on my boom-truck, but 9K trailer will be fine. Further-a typical 6K forklift might rack back and scoot it, but probably won't get it on a trailer.
                      Thanks for all the help,,,I'll try to post some pics when I load this lathe on my trailer should be fun,,,Billboard
