Wow, as Evan stated its pretty easy to make these nuts.
To get familiar with the process I made a "test nut" for a piece of 5/16"-18 threaded rod.
I was concerned that if the heating wasn't done very carefully that at some point the acetal would get too blobby and melt away from where I wanted it to stay but that didn't happen. It got soft and deformable but not blobby.
I just used light spindle oil on the threads for this test but if anyone has come across a better type lube or compound to put on the threads prior to heating please chime in.
I used a heat gun but the real screw will be 5/8"-18 and I don't think the heat gun will cut it on this big screw so I'll use a propane torch for that.
Paul T.
Paul T.
