Engine project
  • Engine project
    Building a V4 from scratch;
    http://moto2-usa.blogspot.com/2010_03_21_archive.html
    Paul Compton
    www.morini-mania.co.uk
    Interesting build. For the prototype, they're taking a Kawasaki Ninja head, slicing it on a bandsaw, and TIG'ing the water channels closed:
    "For our first engine iteration we will be using sectioned ZX-6R cylinder heads to enable us to develop a stable and low loss bottom end without chasing induction, combustion and exhaust issues.
    Scott Kolb of Kolb Machine, was willing to do a quick test head and see how the passages would seal up and the resulting heat input affected valve seat retention and deck flatness. A cheapie eBay head served as the test mule and taking it to the bandsaw resulted in the following part to be welded:"
      Looks almost like a Honda CX engine with two more cylinders. The engine being above the transmission sure makes it tall.
      Looking at the rendering I want to say, Oh, another one of those. Why?
      Gene
        Precisely my first thoughts as well.
        Looking a little deeper gave me some insight into their design philosophy.
        The overall engine assembly is very short front to rear to enable a long swingarm in a short wheelbase. The resultant slight additional height compared to a normal I4 is easily accommodated by the unique chassis needed for the Hossack-style front suspension.
        Lots of machining content on this page:
          This is interesting,
          http://moto2-usa.blogspot.com/2010/0...-overview.html
          But then why oh why did it make old Harley cry.
          http://www.blaisracing.com/assets/images/guessbike4.jpg
          Gene
            I don't see how making it a V-4 shortens the engine, since they are reducing width across the bike not front to rear. It still has to have a gearbox!
            One thing a V-4 definately does is increase the part count, internal frictional losses and raise the center of gravity of the engine - none of which are desirable.
            Monarch 10EE 1942
