A local friend is trying to use a die to cut 5/8"-18 UNF threads on
0.625" x 0.125" DOM tubing.
He called me to say that the die is not doing the job. In efforts to
proceed, he has turned down the OD of the material below 0.600"
but is finding that while the die will start to thread, in short order
it ceases to pull itself forward and then damages the threads already
cut.
The die is a P&N, mfd in Australia.
When I checked for Major Diameter for a 5/8-18, I found tolerances
as follows:
Major Diameter
Max Min
1A - 0.6236 0.6105
2A - 0.6236 0.6149
3A - 0.6250 0.6163
I have suggested turning a fresh section down to about 0.6105 (1A Min)
to see whether the die needs more engagement to thread successfully.
I imagine that the DOM tube is both gummy and hard for trying to thread
with a die. Any suggestions (annealing?) that might help this are welcome.
I am traveling out to his site this afternoon. I am not sure whether there
are tools or bits there for threading with his lathe. My usual holders are
too big for his toolpost, but I am going to check whether I can cobble
something together.
cut.
as follows:
Major Diameter
Max Min
1A - 0.6236 0.6105
2A - 0.6236 0.6149
3A - 0.6250 0.6163
something together.
