Hi Folks,
I am pressing a collar onto a shaft that will have to sustain torsional loads during its lifetime. The collar will be welded in addition to the press fit, but I'd like the press fit to take the loading more than the weld. Are they any set guidelines or rules of thumb for the amount of interference fit given variables such as thickness of each component, temperature of each component (freezing the shaft, heating the collar), or available pressure to seat the collar?
Any tips will be appreciated.
Thanks, Derek
Thanks, Derek
