interesting lathe bed
WEMARA is an ex-GDR company.
"VEB Werkzeug- und Optikmaschinenfabrik Rathenow-MŮgelin (WEMARA)"
They built lathes and machines for the optical industry.
Second op lathes were mostly used to make the "other side" of a part turned in an other lathes. Often enough it was just planing and cutting to length or other simple ops. Also used to reduce the load of a more expensive lathe and finish the part on that second op lathe.
They often lack essential thinks like thread cutting etc.
Nick
I knew that reminded me of something. The Willson lathe is another slant-bed.
See http://www.lathes.co.uk/willson/index.htmlRichard - SW London, UK, EU.
Originally posted by rohartI knew that reminded me of something. The Willson lathe is another slant-bed.
cheers Tom...
It looks like a decent machine,
Hardinge CNC are slant beds and I have used an Empire slant bed also.
Solid and they control chips and coolant flow.
The collets look strange. If you are interested, check collets for both quality and availability first.
Can you put an XY top and cross slide on it easily?????
K Liv
