OT: Help needed on 12V winch as used on ATVs
  • OT: Help needed on 12V winch as used on ATVs
    I want to use a 12V battery operated electric winch on my 54 foot telescoping antenna tower. This particular winch came from, oh gawd this hurts, Harbor Freight and is remote controlled with a keyfob type device.
    I topped off my 12 V car battery with the charger. The winch cable is not hooked up yet till I get the thing running the way it should. When I activate the keyfob remote the winch turns about 1/2 way around and stops. If you hold the button down you get the same thing but it starts turning again and so on and on. The button is for start and stop for winching in and another button for winching out.
    I am afraid the starting and stopping is going to make it very hard on the steel cable. Any ideas?
    As always thanks for your help. I did do some simple machining on the antenna system mounts and will post those even though they are kind of mundane looking!!
    This is the one I have. At $69.00 the unit is a steal even if you gut the remote 60 amp switching relays off of it and throw the winch away!!
    http://www.harborfreight.com/camoufl...ead-95912.html
    sounds like relay wiring is not correct......?
    I spent most of my money on women and booze, the rest I just wasted.
      Forget the remote control and hard wire a pendent to operate the winch. One button for forward one button for reverse.
      The thing sounds dangerous.
      Gene
        Thanks guys, I'll try it without the remote, that will tell me at least which is at fault.
          Remote that uses 'start' and 'stop' buttons (ie will continue without the remote being active) on a ATV winch most likey strong enough to snap something should it run outta line... Sounds very bad.. (dead battery, random button failure, droping it, droping it in water, etc, many things to go wrong)
            Did you look at the feedback in the link?
            It did not score very high and some saying junk, the last one mentioned pulsing on/off and the Manuf. saying 'this is the way it is supposed to work'??
            Max.
              It might be disigned to not wind unless there is some tension on the cable which would otherwise cause the cable to bunch up and jam on the drum.
                Max.
                I hadn't but I have now. Quite a glowing recommendation huh? Looks like junk. Think I'll abandon that plan with only about 4 hours into the project. Don't want to finish it with product showing so little promise.
                Thanks everyone for your help.
                  Yea, Just buy a hand winch insted
                    I have the Rolls Royce of hand winches, that's why I want electric. Much easier to hold down a button for two minutes then to turn handcrank for four minutes. It leaves me in a lather of sweat. Also takes a lot of balls to do it when the lightening is raining down around you and you want to crank the tower down That's why I really liked the idea of the remote. I ran the other winch without the remote and the suggestion by someone above was corrrect. The constant pausing was part of the remote circuit.
                    Link to follow:
                    Im going to use this winch which I also have but never used. Then just for $hits and giggles I decide to read the entire instruction sheet and notice this:
                    WARNING: Handling the cord on this 5. product will expose you to lead, a chemical known to the State of California to cause cancer, and birth defects or other reproductive harm. Wash hands after handling. (California Health & Safety Code ยง 25249.5, et seq.)
                    Guess I'll be washing my hands after each use or become a mad hatter if I don't
                    http://manuals.harborfreight.com/man...2999/92860.pdf
                      YOD: Is your tower steel or aluminum? What kind of mount on the bottom. What machining did you have to do to mount the winch on the tower? My tower is manual, 40 ft. and aluminum. Not so heavy, but i am having trouble finding a good mount for it.
                      John Burchett
                      in Byng OK
                        The motor makes electromagnetic interference which could interfere with the RF remote; I have seen it happen on other stuff. Someone in one of the reviews suggested that it was trying to limit the duty cycle on the (undersized) motor.
                        I didn't like the part in the manual about playing out continuing for a couple seconds after you release the button.
                          The small Champion winches sold by tractor supply for ATV use are much better than the Harbor freight junk. Mine was $79 last year, it has worked quite well with its wired pendant.
                            I have a Tri-X 54 footer that has three stages, 2 stages telescope and move up to 54 feet. It's all planted in hole 36" diameter and 7' deep filled with re-rod and concrete . Four 1" bolts stick up through the concrete and a 5/8's plate steel is bolted to that with the tower mounting tabs welded (PROFESSIONALLY AT $150.00!) that. This arraingement allows me to switch tower in the future if wanted.
                            The tower has a mounting plate on the side of it for the hand winch. I simply removed the handwinch and drilled new holes for the crappy winch. Now I get to drill a new set of holes for the next winch I plan to fit it with.
                              [nitpick]
                              Wrong natural element. Hatters went insane from mercury exposure. Mercury was used in the preparation of felt used in hats.
                              ...will expose you to lead, a chemical known to the State of California to cause cancer...
                              Firstly, lead isn't a chemical, it is a natural element. I know some call natural elements chemicals but I don't subscribe to that definition, nor do many others. Chemicals are compounds of natural elements.
                              Second, elemental lead is not a carcinogen. In fact, there is no clear evidence that even inorganic lead compounds are carcinogens. Toxins, yes.
                              [/nitpick]
