A while back I remember one of us looking for square or rectangular cast iron, I think it was Ringer, try www.interlloy.com.au they are based at Minto near Cambelltown.
Will
I am pretty well covered otherwise - but I need to check my aluminium supplier as I haven't used him for a while and I need some 210mm diam x 30mm thick bar or 210 square x 30mm thick plate. That is above the Interlloy max diam 170mm.
What they list and what they can supply it two different things... I conrtacted a lot of metal suppliers earlier in the year and they all say the same thing when it comes to square and rectangular bar..
