Oxygen regulator still shows pressure after draining torch
  • Oxygen regulator still shows pressure after draining torch
    After I finished using my OA set yesterday, I closed the acetylene valve and drained the torch. Both sides of the acetylene regulator showed zero pressure. Then I did the same for the Oxygen side, closed the valve and drained the torch. But the high pressure side of the O2 regulator shows 20bar pressure, while the low pressure side shows 0.
    I first thought this is the same issue I had with the acetylene cylinder, where the valve was leaking. But this can't be the case, because then the input pressure would be 150bars. But it is lust 20 bar. Is the regulator dying?
    I've seen that happen, and found I can get the tank side pressure down to zero by turning the regulator handle in while the torch valve is open, then out after the pressure is relieved.
    I used to always release the pressure on the valves on my own O/A outfit, but the ones at the school seem to do just fine being left on overnight, or even for days at a time. I always close the tank valves when I'm trough for the day, but it's impossible to get the youngsters to do that all the time.
      I think this is kind of normal.
      What I do, is close the tank, (almost never) drain the hose and close the valve behind the regulator*). If the high pressure rises a bit, I'm not concerned that much. Only if the high pressure shows the tank pressure, there is something wrong with the tank valve.
      Just my opinion, I might be wrong.
      Not all regulators have that feature, my argon regulator (real flow through; the one with the ball) misses it.
      Nick
        I've never seen anyone who preforms the ritual described above putting their car on jack stands after driving. Isn't it the same principal?
          I shut down the main tank valves, open the torch head valves until everything relaxes to 0. I then close the regulators down and then back out the screw until I know I've take some of the pressure off the rubber valve seal. My pressure regulators both stick if left fully out for several days. I've never witnessed any residual pressure on my tanks and I am always watching for it. Tanks that bleed are a little scary to me.
            I have a Victor set that is now about 25 years old. Close the tanks, release all pressure and then close the torch valves. If it is to be left for a while then I back off the regulators. Either way there is zero pressure on both gauges and it stays that way.
              From your description it sounds like the high pressure gauge is not returning to zero. If it were the regulator there wouldn't there be pressure on the low pressure gauge?
              Byron Boucher
              Burnet, TX
                When draining the oxygen hoses, I have the cylinder valve shut, the regulator and torch valves wide open. What seemed odd is that it took a very long time for the hissing to stop. Maybe it didn't even stop and maybe it became so slow that it wasn't audible anymore. At this point, the low pressure side showed zero and the high pressure side was at 20 bar.
                Another weird observation (didn't happen before) is that when I cranked up the regulator valve, I clicking and rattling sounds from the regulator. Can it be that the high pressure side has lost its sensitivity, where it properly reduces high pressure O2, but stays shut if the pressure drops below a certain threshold?
                  Not sure I understand this
                  Are you saying I shouldn't bother relesing the pressure? Just shut off the tank, the regulator and torch valves and be done with it?
                    In my mind, shutting the tank valves is a safety step that should be done whenever the rig won't be used for a while or whenever it'll be unattended.
                    I used to think relieving the pressure on the regulator and torch would prolong their life, but that appears to be unnecessary based on what I've seen at the school.
                    The car on jack stands analogy was lost on me, too.
                      Random thing iv noticed: While venting the actylene tank, the output pressure of the regulator goes *up* as the input pressure goes down.
                      Result? If you had it at 10psi, it might go over 15psi before the tank is emptyed. Allways insure your acetylene regulator is set 'low' (5psi or less) before venting!
                        He forgot to say, that he is releasing the tire pressure.
                        Nick
                          The critical pressure for self detonation for acetylene is actually about 30 psi. 15 psi is always used to give a safety margin.
                            IMHO after twenty years repairing regulators and torches it does not make any difference, close the tank for safety close the valves on the torch for safety and store the torch. if you have a leak the gauges will go to zero, most welding sets have a small leaks somewhere, most of the time where the regulators fasten to the tanks (small nicks,scratches etc on the seats). Find it with soapy water tighten the fitting to stop the leak or just live with a very small leak. my two cents worth.
                            re
                            Herm Williams
                              It's a bad gauge. Most weld shops sell replenishes. Usually under $10.
