Nutserts, I want the opposite.
  • Nutserts, I want the opposite.
    I have a nutsert tool and a selection of nutserts, but want to know the correct term and source for the ones that are not a nut, but have a threaded bolt type section instead. I suppose you would call them a stud?
    Nev
    Nev.
    The ones I have used are called PEM studs:
    http://www.pemnet.com/fastening_prod...for+Sheetmetal
      Pem studs, self clinching studs.. All the same thing concept wise...
        Bugger. Links did not work.
        nev
        Nev.
          The folks with the PEM brand/trademark (Penn Engineering and Manufacturing, IIRC) do a lot of things just like what you refer to.
          Nuts, studs, spacers and standoffs, snap-top standoffs (for PC boards) etc. Pretty much all of them require precisely sized holes and special equipment to seat them right. I HAVE seated them in softer material with cruder tooling...
          "Nutserts" as I know them, are a crimp-in type, typically with a collapsing flanged tube that ends up with a flange on both sides of the sheet metal. They can be inserted with a simple hand press.
          I am not aware of a stud version, but I have never looked for one.
          Alternatives are butt-spot-welded studs etc which are commercial items, typically with welding protrusions.
            How big do you need the studs?
            For sizes 10 mm +, automotive wheel studs are widely available. Just press them into a drilled hole from the back. Some even have a square shoulder ahead of the knurl that will broach the last few thou off an undersize hole if you push hard enough.
              McMaster have a stud version -
              http://www.mcmaster.com/#studs/=93907x
              but they are only imperial. Where you get them in Oz, I have no idea - I usually have to go to McMaster for some of this more interesting hardware.
              Michael
                That's them.
                Thanks for the link. These are what I am after but in metric. 5,6 and 8mm would be good to find.
                http://www.mcmaster.com/#studs/=93a256
                This is the type of tool I have.
                MFX612s
                http://www.masterfix.com/uk/mfx-612s.asp
                Nev
                Nev.
                  Nev
                  Like this ?? (video @ bottom)
                  http://www.boellhoff.de/en/de/fasten...ogy/rivkle.php
                  from -
                  http://www.hengze-fastening.com/blin...rivetstud2.htm
                  or
                  http://www.harrisonsilverdale.com/pr...RIVETNUTS.html
                  john
                  John
                  I used to be indecisive. Now I'm not so sure , but I'm not a complete idiot - some bits are still missing
                    Nutsert?
                    Why not just use a standard nutsert and locktight a piece of threaded rod into it?
                      Have thought of that but would prefer the proper fitting if available for a reasonable price. It would also mean I do not have to purchase the mandrels for the studs which I don't have at the moment.
                      Nev
                      Nev.
                        Originally posted by jugs
                        Thanks for the link. I see they offer samples. I'll see if someone I know on another forum over there can get samples and send to me.
                        http://www.harrisonsilverdale.com/fa...6/TPL/189.html
                        Nev
                        Nev.
                          Yeh lern sompin ever day.......
                          I never saw those before, but for sure they are the "opposite" type to a "nutsert".........
                            Nev
                            You dont NEED a mandrel - 2 greased washers + a nut + spanner
                            & only slightly slower than the mandrel.
                            john
                            John
                              Found someone in Oz who has some. Here's the link in case anyone down here is looking for them.
                              www.profast.com.au
                              Nev
                              Nev.
