Ot- #*!$*@!! Vista
  • Ot- #*!$*@!! Vista
    Let's just say I hate Vista. But....
    Since that is what's on the war wagon's laptop, I (we) cannot figure out how to connect to the internet with it wirelessly. It finds my network just fine, and it can talk my other machines, but it WILL NOT connect to the Internet. Vista has a "map" that shows active paths. The map to the Internet is X'ed. I've tried private settings, public settings, and, well, just about everything else I can think of. But I haven't hit the combo right yet.
    Any of you sharpsters out there know how to fix this POS? Yeah, I know, delete it and get Win7, Linux, or whatever. NOT AN OPTION.
    Cummon guys- help me out. Maybe it'll get her off my back for a minute or two.
    Amusing. Right now I'm fighting with a Win7 laptop, trying to get it to disconnect from a non-functional network from work, so I cna connect it to my home network. I've been working on it for 2 hours. So far, I haven't seen anything like a "disconnect from network" option.
    Nor, so far, does it see my home network.
      I had a internet problem with my laptop with vista as well. I found a switch on the front bottom of the laptop that turns wireless on and off. lol
        Click on the little in the tray bar, click on the connection you want to disconnect, and click "Disconnect"
          When I click that icon, I get a little popup that says, "Unidentified Network / no internet access." There is no option to disconnect. I have a link for "open network and sharing center" but I can't see how to proceed once I get there.
            That means you're not connected.
              It won't let me connect to anything else because I'm connected to it.
              And it won't discover the same wireless network I'm using right now.
                Garagemark, try looking at your firewall settings, or disabling your firewall on the Vista machine. You're behind a hardware router already, yes?
                  The XP/Vista/Win 7 wireless discovery works even when you're connected to another network. If you can't click on the active network in the try tab, you're not connected.
                  I've walked several relatives through connecting WiFi over the phone, and I'd rather have a root canal. To make things simpler, start with all authentication (WEP, WPA,..) disabled, the router disabled, the firewall turned off. Once you get that connecting, then systematically start turning your security back on. Make sure you enable WPA (wireless authentication).
                  If it makes you feel any better, it's far worse to set it up on Linux.
                    HaHa
                    Exactly. One of you guys is going to have to go over there and stay for a week. Mine is working pretty well now but it's been about 18 months of lots of different people helping.
                    I still have to do some strange things that make no sense about once a week but I'm happy, for now.
                    Don't have Vista, happy about that too.
                    Good luck.
                      Do you have access to a building with two or more stories? If so I'd like to recommend the "drop test".
                      The other option is to upgrade to XP.
                        http://www.wirelessforums.org/how-to...ing-96070.html
                          Where does your wireless signal come from? Can you take your laptop to another location with wireless and see f it works there.
                          There could be a problem with your wireless router/modem or what ever your using. Try restarting the router and modem.
                          Sometimes I loose my internet connection and restarting the router and modem solves the problem.
                          I had a wireless router that failed and would not let me connect to the internet. The laptop could see the signal from the failed router and
                          connect to it but not to the internet yet all the internal settings were correct.
                          Like someone said earlier check for a wireless switch on the laptop and make sure it is on, I fell for that once.
                          What are you using for wireless hardware?
                          Terry
                              I have a switch. Instead of troublesome words, they have "orange" and "not orange" lolz.
