I have a delightful stretch of rough concrete across part of the basement (that last word is pronounced "shop") of which most is slightly below the general surface level. It was a trench about 18" by 10 or 12 feet, which the plumbers concreted.
I got there before it was hard, and found the surface mounded up..... which was totally unacceptable. I rapidly ground and scraped it down to a general slight depression, much of which has pits from the over-size gravel that was torn out of the surface when I dug and ground it down..
This is from a drain replacement a few months ago. I had some other work done, and just now have got to fixing this lousy surface.
Quickcrete have a "resurfacer" compound that seems to be Portland cement, very fine sand, and some polymer additives. This stuff is supposed to be good to a 1/16" layer. It appears to NOT be an "underlayment smoother", and does not need to be covered.
The main questions for anyone who has done this are:
how thick is the mix when used? to spread out to a thin layer, it would seem it needs to be almost a bit soupy.
is the 1/16" practical? I have spots in this where the 1/16" will really be the thickness, although much of it is going to be thicker.
They recommend a squeegee to spread it, which suggests a thinnish surface, but the surface may need some sort of floating or troweling to smooth it for real, can this be done on such a thin coating in any reasonable way?
I am going to have machines over this area, so the surface does need to be sensibly durable.
Thanks for any input from those who know..... I'm definitely not a concrete worker, I am barely OK as a tuckpointer.
