Collant pump repair
  • Collant pump repair
    First, I would not make a pimple on the posterior of a machinist or photographer so please view the following accordingly.
    This is a coolant pump from a lathe that needed a new bottom. I don't know what they used for coolant but it was not too good for the pump body. I used a dissimilar metal for the repair so hopefully it will hold up.
    Piece of scrap for repair material.
    Making chips.
    Side 1 done.
    Test fit. I guessed .010 clearances for the impeller.
    Repair done. Paint that will probably last about 2 seconds.
      Well done, considering the condition, it's surprising that you were able to get the bolts out.
        Ya did good,both on the machine work and the pics
          lol at shiny cover on the old corroded pump.
          Next weeks project: new coolant pump body
          Nice work reguardless!
            Thanks very much for the comments.
              As others have said, very well done.
