Lathe, How fast can I go??
  • Lathe, How fast can I go??
    Hi, I have been offered an old (1930 ish) Colchester Master with a top speed of 550 rpm or so, How fast can I make this thing go(by way of faster motor & pully's etc)without blowing the shed up.
    Idealy I want 1500 RPM.
    Does anybody have any info on this type of lathe OR Does anybody in the U.K have a 36" between centres lathe with 1500 RPM Screwcutting gearbox and a clutch that they want to sell?? If so please drop me a line with your phone number and I will give you a ring
    Thanks, James.
    The question is what kind of bearings and lubrication system does it have and what diameter are the bearing jounals if is babbit or broze bearings
      Thanks Spin doctor, this is the problem... not knowing anything about the machine, and it's 500 miles away!
        Have a read here. It appears that some of these models were run up to 1500 rpm.
        http://www.lathes.co.uk/colchester/page2.html
          Just guessing, I'd say the spindle bearings shouldn't have a problem at 1500 rpm. I'd be more concerned about the maximum safe speed of your chucks.
          The noise of the gears may be pretty alarming "at speed," but I doubt it would be dangerous.
            For you Nubies out there, all chucks are rated for max speed. run them too fast and they can explode.
            Case in point, we bought a 36" Pyoreba (Polish)lathe with a 28" chuck the lathe was geared to run 1400 as I recall, but the Cast Iron Chuck was only rated for 900 Rpm.
            Scrap the chuck and bought a "Semi Steel" one which had a higher speed to match the RPM of the machine.
            So always be aware of your max capability on chucks, and of course Cast Iron is great stuff, but Semi-Steel is needed for the R's
              Rich
              Good point. I can run my lathe to 6000 because it has a forged steel chuck rated for 6500. If James is unsure of the limit of the chucks he has he should not change the speed at all.
                Thanks all, perhaps i'll give this one a miss and look for a more sutable machine, There are plenty of short bed lathes out there but I make bagpipes and need to mount 16" gundrills in the tailstock, so longbed versions are a must.
                James.
