Exhaust for a small motor
  • Exhaust for a small motor
    I have a 6HP Kohler on a leaf vac and the way it sits the exhaust comes right at me. Can I make a little exhaust pipe for it out of tubing and solder it on? Will the extra length cause any problems?
    Thanks,
    Rich
    Unless you are planning to race the leaf blower.....NO a little extra exhaust pipe will not hurt anything. Even if you were going to race it it may help, but doubtful.
      Yeah. not a problem redirecting the exhaust, but you'll have to weld or at least braze it as conventional solder will not withstand the heat.
      Bad Decisions Make Good Stories
        The K91(4hp Kohler) on my vac system uses a piece of rectangular tube bolted over the exhaust port with 2 holes drilled at the opposite end.
          You know, a better question might be to ask who the DA was that designed such a stupid arrangement.
          I riveted a piece of sheet metal on my blower exhaust, but I was not getting gassed, I was getting burned. It's a kind of shroud that doesn't get nearly as hot as the muffler.
            The one who did not have to take any hands on labs in engineering school.
              On mine the "muffler" is that way because the blower housing is in the way.
