Dro ?
  • Dro ?
    Guys, i'm cleaning up a Bridgeport mill and getting it ready for service. Most of it's use will be for building model engines. I'm planning to add a DRO, and was
    interested if anyone had any comments of a DRO PROS vs the Analam 411. I plan to get the 2 axis version. Pros, cons...
    neonman
    Look round for the original graduated steel scales and light boxes that were fitted,(Pre Heidenstien) ---- NEVER skipped a beat.
    Regards Ian.
    You might not like what I say,but that doesn't mean I'm wrong.
      Regards Ian.
      While you are at it look for the treadle conversions and carbide lights................
        Hmm, I'll be more inclined to sympathize with your disdain for BP's when you get rid of yours....
          Probably more a comment on older DRO technology. I had a friend who said he really loved old machines -- so long as he didn't have to make his living on them. I'll second that. I don't have a DRO and when I'm making a new dividing head hole plate circle with the dials on my machine, the plus and minus X and Y with backlash elimination is a nice machinist's challenge. If I had to make rate on that I'd have a different opinion.
            neonman
            Anilam makes a good box.
            There is also the Newall M20 which is good if you only need 2 axis
            Cant reset, do abs/inc modes, hole patterns, inch/mm conv, with mechanical scales.
              I have the Newall M20 and like it. Be sure to get the newer version without the internal battery.
                Analam
                Experienced and reliability
                Made in USA last I looked
                  Dro
                  I've had very good success with Accu-Rite and Mitutoyo over the years. Right now I'm running a 2 tenths Accu-Rite Master MP that is about 15 years old and looks and works like brand new. You don't really need a 3 axis because gravity keeps all backlash out of the Z axis knee screw. That makes the dial plenty good enough.
                    If you can get one with a bolt circle function, you'll find it very handy, for lots more than bolt circles.
                      One of the recommendations I got was for the Newall solution due to their linear encoder. Their warranty has a no fault clause if you can break it they cover it for three years if I recall.
                        The 411 is real nice and very reasonable priced.
                          Thanks guys, I think I'll go with the Anilam since Enco has a 15% deal
                          until the end of the month.
                          neonman
