Micrometer Stands
  • Micrometer Stands
    I ahve seen the basic micrometer standsw in the catelogs, do any one have the plans for a really slick one? Even photos would help.
    Thanks,
    Jerry
    Jerry
    WHATSAMATTAFOYOUANYWAY?!!
    You should be showing us the slick one you design - seeing how you have an eye for form and function and all! We is not worthy...
    It should have a heavy base, adjustable clamp to hold mic at different angles and posistions. Sometimes it is nice to have a stage to rest an item on so it can be measured - important with small delicate/heat sensitive items. SO figure it out and surprise us - I believe in you.
      I've been a machinist most all my life and worked all phases of dimensional inspection for about 6 years and never had a need for a mike stand.
      But a nice cast iron adjustable mike stand with a black crackle finish and pretty knurled adjustment knobs is a handsome addition for a shelf in the inspection area. Kinda like a cookie jar shaped like a rabbit or a cabin in a logging camp cook shack.
      Damn new fangled sissified fripperies. Oughta be a law.
        What in hell, is a cookie jar???
        I use clean shop towel laid on the granite plate to hold my mics I am using or the tool caddie beside the lathe or the main toolbox. Never thought of a mic stand but seeing how I am all thumbs now it might not be a bad idea. Thanks Forrest!
          Here's one:
          Looks like one more reason to get busy with the ball turning toys.
          Roger
            Something like this would work well and cheap, has a vacuum clamp to mount most anywhere with a smooth surface. Found this in Penn State Ind. catalog.
            http://img4.photobucket.com/albums/0...-VACVISE-T.jpg
            Paul G.
            [This message has been edited by Paul Gauthier (edited 12-13-2003).]
            Paul G.
