I know we have some top notch auto repair folks here, so maybe a bit of advice, please:
The patient is my son's 1998 Chevy Cavalier, 2.2L 4 cyl, single cam. Fuel efficiency has dropped quite a bit, and we got a check engine light. Read the code, and it gave "P0420 Catalytic System Efficiency Below Threshold (Bank 1)".
A bit of research gives me generic advice that at idle, I should see a fluctuating signal on the upstream O2 sensor (sensor 1) and a pretty stable signal of about .5 or .6 V on the downstream O2 sensor (sensor 2).
My OBD reader can graph sensor outputs, so I set it up to look at those. The upstream sensor does indeed show a fairly regular signal, fluctuating between about .4 and .8 volts. The downstream sensor is pretty steady but may be a bit high at about .75 volts.
The major culprit would seem to point to a clogged or failed cat converter. I also know that blindly following OBD codes can occasionally send one barking up the wrong tree. Hence my inquiry here.
Anything else I ought to check or do before I go and change out the converter? The cat does not look too difficult to change in this car, but I'd hate to do it and not fix the problem.
Thanks for any advice.
-Al
-Al
