Emco Compact 5 lathe spindel
  • Emco Compact 5 lathe spindel
    Looking for information Emco Copact 5 lathe. I need a drawing of the
    headstock spindel bolt hole lay out. Anyone have the dimensions?
    I need to make a new adaptor plate for a new 3 jaw chuck.
    Any help would be greatly appreciated.
    Thanks william
    Tried the yahoo group??
    Regards Ian.
    You might not like what I say,but that doesn't mean I'm wrong.
      William....Measuring my Compact 5, the spindle is 40mm diameter, bored 16mm. On the mounting face there are six 5mm tapped holes (0.8mm pitch) on a 29mm PCD - 4 holes are at 90 degree spacing for the 4-jaw chuck; the other 2 holes are spaced 120 degrees from one of the first-mentioned 4 holes, thus providing the holes for the 3-jaw and the collett adaptor.
      As my machine is quite old, can I suggest you check the PCD by screwing in two M5 bolts or cap screws into 2 holes that are 180 degrees apart and measure the distance between them on the outside, subtracting the diameter of one bolt / screw to get the PCD.
      Dennis
