OT - Lens polishing
  • OT - Lens polishing
    I've got an older pair of glasses, standard plastic lenses, with a UV coating that is flaking off. These are the glasses I wear when things are flying and don't want to risk damage to my good glasses. Is there a fairly simple way to remove the entire coating?
    Thanks.
    Steve.
    No.
      I was pretty sure that is what the answer was going to be but thought I'd check anyway.
      Maybe I'll build a CNC lens grinder to skim off a thin layer!
      Thanks.
      Steve.
        straight (99%) isopropyl alcohol will take off (or at least loosen) some eyeglass coatings ... don't ask how I know ...
        and yes I was able to remove the entire coating once it started
        Tom C
        ... nice weather eh?
          I am fairly sure that a belt sander will take it off without much effort. Or a disk sander. Or, well you get the idea.
          A little extra pressure and it will remove both sides in the same operation.
          Make it fit.
            http://arcoatings.com/
