Oil for my eaton compressor
  • Oil for my eaton compressor
    what kind of oil do you use for you air compressor? I was thinking of royal purple Synfilm Recip. 100.
    Any thoughts?
    Rob
    Rob
    If its a piston type compressor most any SAE 30 weight will do just fine. You could Google the name and model number to see if you can find a pdf of the manual to see what is recommended.
      I use air compressor oil for my air compressor... Princess auto brand.
        I use a synthetic Estrolene 30 wt. A friend works for a pipeline company they use Mobile Synthetic but I can't read the lable for the number.
        Byron Boucher
        Burnet, TX
          I've used Campbell-Hausfield, Mobil 1 15w-50, and lately, 30wt non-detergent with no apparent difference. It seems that everyone recommends 30wt non-detergent these days so that's probably as good as anything.
          BTW, my compressor is a large two stage 80 gallon vertical with a 5 hp motor. It's still running nicelt after nearly 15 years so it must not make much difference as long as it has some oil in it.
