Two Jaw Vice?
  • Two Jaw Vice?
    I need to build a small vice that will center the workpiece when tightened.
    The maximum opening just over 2".
    I cannot figure out how to do it simply. I have figured out ways to do it but it becomes to bulky.
    This will be used as part of an attachment for my belt grinder to round the ends of material. The vice will sit on a cross slide type of mechanism in order to feed the workpiece to the belt as the rounding process progresses.
    The reason is so I don't have to drill a hole in every piece I want to round the end. The pivot will be under the workpiece.
    I have a self centering bar vice, so what you are looking for is made. I don't think it would be all that straightforward to make, so you might be better off just buying one. You should perhaps try a search on ebay, you might well be able to pick one up at a decent pice.
      Make a threaded rod thats half left hand and half right hand threads
        Self centreing
        here is a recently completed project ..Well... part of it .
        from looking at it , it should tell you how i got this door drilling jig to be self centreing ..and may give you an idea how to make a unique vise .
        anyone finding photobucket very clunky ..its gone to pot .
        all the best.markj
          Centering Vise
          You make a groove in the middle of the right and left threaded rod and a stationary U section in the base or hold the rod from moving at the ends. Once you get it all together, get the closed jaws centered on the pivot point and dowel pin the base with jaws centered.
            Here's an example of a commercial one, I would think you could pick up a used one for a lot less if you are patient. http://www.shars.com/products/view/5...g_Machine_Vise
              Another possibility for a self centering vice is a 4 jaw scroll chuck with two jaws removed....although that is absolutely no use for your job!
              "...do you not think you have enough machines?"
                That seems to be a pretty reasonable price.
                "Patriotism is the last refuge of a scoundrel"
                  BF,
                  I went throught the same drill wanting/looking to build my own centering vise. After much frustration, I found this one and made the purchase. It's quite a nice little vise, much better than what I was trying to make.
                  http://www.grizzly.com/products/Prec...ing-Vise/H7576
                  Regards,
                  HAP
                  Who do I think you are...?
                    Posting attachment?
                    I made a PDF of what I want to build......but I can not upload a pdf to Photobucket. Any ideas how I can let you all see this PDF?
                      That vise from Grizzly might work!
                        Small self centering vises
                        wood working folks use a small self centering vise for
                        drilling pen blanks before turning. search for Penn State Industies
                        or any of the stores that sell pen turning kits and supplies
                        Mark
                          Originally posted by aboard_epsilon
                          Self centreing
                          all the best.markj
                          Thats why I switched to flickr. It creates BB code for the size of pic you want to post.
                            A brace and bit type drill uses one up to 1/2" but I never paid any attention to how it worked.
                              jpg file > PB
                              Either out-put the original file to *.jpg or scan the hard-copy of the *.Pdf file and out-put that as a *.jpg file.
                              Then up-load the jpg file to Photo-Bucket as usual.
