[Tool Gloat] Fairly Substantial "better than a Dremel " for $5!
  • [Tool Gloat] Fairly Substantial "better than a Dremel " for $5!
    We have a not-for-profit "Used Tool" shop that just opened. They have lots of tools, good and bad there. They accept old tools, power tools and machines, clean them up, test 'em out and sell them CHEAP. Goal is to raise money for one of the church food-pantry programs. I 100% approve of trading money for tools if some of that money goes to help people who need such help.
    Anyway. It runs... very very smooth. Goes from fast to OMG FAST, twice as fast as my Dremel.
    The power box is very substantial too. Good 3-4 pounds, and you can see a [email protected] transformer in there.
    The chuck is a proper chuck too! Got little jaws and everything. Came with two spare chucks still sealed in plastic. Proper chuck with jaws as opposed to those fail-tastic compression-collet things that Dremel uses.
    I'm not sure what this is:
    ...the tool fits in it securely. The metal part moves back and forth and locks with a wing-nut. The plastic piece moves up and down when you turn the knob giving some fine vertical motion. It says Dremel on the front... I think it is part of something else, not original equipment.
    Well, that's my gloat. No one has beat the "Everlasting Drill And Tap Box Of The Gods" yet today this week.
    Plastic Operators Dot Com
    Mystery piece sure looks like a dremel router attachment of some kind.
    Proud machining permanoob since September 2010
      I just noticed something:
      "Made in WEST Germany"
      Amazing that it's lasted this long... Germany has been unified for how long now? To compare, my Dremel is showing wear after only a few months use...
        Liger,
        I think you need to send it to me for testing to see if its safe. I'll get it back to you in a year or so.
        Stan
          My dad has one of these. Got it in the mid-80's. Pretty decent. Bad thing was the two pin connector on the front went bad so I replaced it with a little panel mount twist lock.
          I would say the main problem was the little chuck would not hold well and loosen on its own.
            Originally posted by Dr Stan
            Liger,
            Stan
            Absolutely. I will get it off in the mail to you as soon as I finish building my fusion reactor.
            It gotta be better than that craptastic compression collet thing that Dremel uses.
              The original kit did come with collets and a collet nut.
                Interesting. I have the blowmolded box... All that remains of the "kit" is a plastic sleeve that fits in a compartment. There are all kinds of interesting depressions though so it seems to have come with quite a bit of "stuff."
                  The other item is an old style about 3 version ago compared to the current version Dremel hand router attachment.
                  Glen
                    Is it complete or am I missing pieces?
                      Looks Exactly like my Dremel router base... Congrats on a good find!
                        You know I would gladly pay more for a decent Dremel tool.
                        By decent I mean a cast aluminum case with machined bearing bores.
                          have you seen the Foredoms?
                          http://www.foredom.net/
                            My guess is you'll pay far more for the router bits for it then what you paid for the tool and the router base.
                              ...ain't that the truth!
                              On the other hand, little tiny brass brushes and those feltoid polishing wheels rock.
