cutting circles in 1" plate
  • cutting circles in 1" plate
    Occasionally I need to cut a wheel or pulley from 1" plate. I usually center-drill and flame cut, then finish on the lathe.
    Is there a way to machine these without the flame cut portion?
    Circle cutting
    Bandsaw, holesaw, trepan, rotary table or waterjet.
      If you have a huge shear (that can cut 1" plate) you can rough out your circle by a bunch of straight cuts. If you can solve the workholding problem, you can plunge mill using a rotary table. But by far the easiest/cheapest/fastest way is still what you're doing. You do have a good circle attachment, right? Those are worth their weight in gold. I love mine.
      And if oxyactetylene is the problem, try oxypropane or plasma.
      MM
        Wouldn't it be cheaper and faster to buy a cast iron pully the size you need?
          I use a disc-cutting attachment on my plasma cutter.
          Plasma will have no flame slag, but ~ 1/16" hardened kerf.
            I figured as much, I just get tired of the clean up.
            Pulleys mainly for cable and odd mechanisms so sheaves wouldn't work.
            I should just go buy some 5-6 in shaft for the bigger ones.
            Thanks
              This is the Home Shop Machinist forum we don't DO off-the-shelf-solutions here.
              Plastic Operators Dot Com
                no one locally who can water cut them for you?
                  Its called a trepanning tool. Here's a link.
                  http://www.jtsmach.com/jtswebshop/Pr...Tools/D315.asp
                    Liger :
                    I'm not too sure we go around cutting slices off 6" bar, either !
                    Richard - SW London, UK, EU.
                      Sure we do! Most modern hacksaws have a 12" blade.
                        Originally posted by rohart
                        Liger :
                        ***** (ffs... a thing that goes meow)
                          Band-sawing from a round bar
                          Thanks
                          I wouldn't do that.
                          At some time you are going to have an end left that you will find difficult to fit in your hack/band saw.
                          I just get it cut from round rod/bar by my steel supplier on his very big band-saw. Cost to cut is minimal and I am set to go on the lathe or mill with no hard spots to remove or cutters to be trashed and I don't have the inconvenience or expense of steel round bars sitting around "just in case".
                          I drive past my steel supplier 2>4 times a week - about 10Km (~ 6 miles) round trip. He can cut it dead true (for a band-saw) in a matter of minutes.
                          Its much easier facing off band-sawn faces and hot rolled than it is facing off a "black" face and a gas-cut edge on a disk cut from HR plate.
                            Originally posted by oldtiffie
                            I wouldn't do that.
                            stud into end, bolted to parallel box, c clamped to band saw. Piece of cake
                              Adaption
                              Nice solution Mcgyver.
                              If I am caught like that I usually just tack-weld it to another bit that can be held in the bandsaw vise. Does not need a lot of tacks at all.
                              But on the other hand, if it needs to be cut from plate, I get my supplier to get it done at a local shop that does high pressure water-jet cutting. Its easy to machine and doesn't stress or distort or locally harden the part I want either. Most times non-important water-jet cut faces can be left "as is". My supplier gets it done at a better rate than I can and when he puts his margin on it I get it at a good price as well.
                              I made a conscious decision a long time ago to stop buying or hoarding steel plates and sections as the space it takes is a PITA as is pulling that bit I want out from the back of the stack/rack. I carry small quantities of steel sections and bar, and a bit of brass, bronze and aluminium, but otherwise I just go and buy it on an "as required" basis. Most stuff is available locally or if not its only a couple of days away by order.
                              I've wasted too many hours and too much stock "making do with what's around" and I plan my jobs around what stock my supplier has. He will cut to length for a small nominal charge as well and so the stuff is ready to use "as is" as soon as I get it home.
                              But, as you've shown in your band-saw adaption, you just have to improvise or make do sometimes - but its my last resort.
