D1-4 spindle, should chuck fit flush ?
  • #31
    Originally posted by TR
    The manufacture says the chuck should fit flush against the spindle face. I have a 0.004" gap near number 1 jaw. No gap near the 2 and 3. Maybe I should use a breaker bar to try and tighten it just a bit ?
    this is not a problem brute force will solve
    presumably the pin 1 is engaging with the cam, ie like deere guy says, the pin is the right distance out so the cam catches it?
    Like I said earlier, that is your problem, its mounting like a swash plate. As earlier suggest you need to now determine if its the lathe spindle or chuck that is at fault - first thing is to try mounting any other tooling you have and check it with the feeler gauge....if everything else mounts ok dollars to donuts its the chuck
    • #32
      Originally posted by deere_x475guy
      TR, are all the pins on the back of the chuck screwed in the same length?
      yes, I even tried pins from my other chucks.
      • #33
        Good news. I used a breaker bar to close the .004" gap and now have TIR less than 0.03mm. Pretty good. Pretty tight fit.
        I purchased some spare d1-4 cams just in case. The supplier told me they keep lots in stock because of demand. Typically machinists use a breaker bar to close gaps between the chuck and spindle face and sometime the cams break. Hard to believe.
        Thanks for all the good advice.
        • #34
          Sounds like it's on the taper pretty tightly.
          Have you tried to remove it yet?
          Ian
          All of the gear, no idea...
          • #35
            Ian
            Yes. The force I used on the breaker was not too big. It was just easier. Yes, tight fit. One whack of the rubber mallet and the chuck was loose.
            • #36
              One thing that I've found to help is that you make one pass just nipping the cams up, then a second pass tightening them to the final torque. Pulling the backplate in evenly helps a lot on the level of torque needed.
              • #37
                I know this will probably sound like overkill to most of you and certainly way to slow for the production guys....
                I always....tighen mine just snugging by hand then I actually use a torque wrench and work my way around taking them to 50 ft lbs....Don't remember where I got that figure at...I know it was after I had shoulder surgery and was recovering.
                In addition to the above...when I do get a new chuck I always try all the positions and note the best runout..then make a mark on the chuck so I always index it to the mark I have on the spindle.
                Bob
                Pics of shop and some projects
                http://s2.photobucket.com/albums/y39...achine%20Shop/
                • #38
                  FACT CHECK TIME
                  Having read all the posts, I decided to do a little leg work, and it was rather interesting. I had a machine shop Seminar at a tech college 60 miles way and they have a lot of lathes with DI Spindles. So I asked the instructor for a .001 piece of shim stock. He only had a .0015 so I used it on the 8 lathes.
                  I found that on 6 of them, I could not insert the shim, or see light.
                  On one, there was a .002 clearance and the other was cocked, at maybe .004".
                  Turns out the .002 would not snug tight, but was also not "registered".
                  That means the O--O marks between the chuck and the spindle were not alligned. You always mount a DI with these marks. When the instructor released the chuck and reset it with the marks, it came in to .000" , but he did put a heavy twist on the wrench.
                  The last chuck was....loose on one pin ...and also not alligned
                  But guess what ? Not all chucks AND not all spindles had registration marks !
                  (3 spindles and 2 chucks were void on this)
                  So maybe if your chuck is not pulled against the spindle sufficiently, you have a problem wirh the "connection"
                  Moral of the story is that attention on these issues are important to note and do occur and should be addressed. I know the instructor (friend of mine) is greatful that I brought up the subject,
                  It may have prevented damage or injury .
                  Thank You Home Shop Machinist for the opportunity to promote shop safety !
                  Thank You also to Mr Forrest Addy..your proof was in the pudding !
                  Merry Christmas all
                  Rich
                  Green Bay, WI
