Making a V belt pulley with a parting blade
  • Making a V belt pulley with a parting blade
    Apologies for interrupting the board with my minor HSM triumph. There should be a wink right here but the software counts that as a photo.
    I'm replacing the generator on my 53 Hudson with a modern alternator, so I needed to make an 84mm OD (3 1/4") B-section V belt pulley with 17mm bore. I thought I'd try the job using my 3.2mm carbide insert parting blade, because I've got one of them, rather than worry about form tools, and it all worked quite well. One reason it worked I guess is because I made an aluminium pulley, don't know that I would go too well with a steel or cast iron pulley.
    First job was to make a nice stiff mandrel to stand the pulley blank an inch and a half or so off the chuck face. This was because I was going to be swiveling the compound round at 17° to cut the pulley sides and would need clearance on the LH side of the pulley.
    The mandrel is a piece of 2 1/4" round steel with the end turned down to 17mm, same as the new alternator. The aluminium blank is 84mm x 25mm and is clamped to the mandrel with a 30mm washer and M10 bolt.
    Put the parting off blade in to the depth of the V groove which is 18.2mm deep and also use the blade to mark the edges of the V groove which is 16.6mm wide
    Swing the compound to 17° and take off 1mm at a time until the groove is the right width. As you would expect there is a fair bit of deflection in a parting blade when its only cutting on one edge, quite a few spring cuts were needed before the blade stopped removing metal. At least the insert stayed in the holder, which was another unknown.
    All done and ready to go to work.
    I have made many a pulley in similar fashion. I use a stick of HSS and just grind a cutting tool with the correct angle on each side with a parting style edge on the front and zero top rake. It saves a lot of fiddling around with the compound.
    Nice work, make sure the belt doesn't bottom in the pulley.
      Good job Bob!!
      You probably would have had success also in both cast iron and steel with this method. You may have had even more deflection in steel, but you can alleviate that somewhat by leaving the parting tool square to the spindle center line instead of turning it to be parallel to the compound travel. You should be able to do this as long as the root width of the groove is wider than the parting blade.
      One of the major advantages of this method is the lack of chatter, as there is much less cutting edge engaged as compared to using a form tool.
        Nifty. I made a tool that might help with such tight grooves.
        Its a forked devil toung tool! I'll get a picture if anyone wants.. But basicly, its the equvilent of a left AND right hand tool in one, with a recess in the center beween them, And a lot of side relief on both sides.
        The usage is you plunge in slightly, Then move the tool sideways at least one width of the tool. Then your free to plunge in again, And move back.
        Idea being it keeps the amount of tool in contact with the work to a minimal amount (Just the two tips) insted of the whole tool face, And allows you to do most of the removal work by moving side to side, Insted of plunging in.
        I used this tool on the end of a boring bar to cut an ID groove and there was no chatter at all, And you can face both sides of a tapered groove with one tool without adjusting its angle, as well as turn the bottom smooth.
          Pics please.
            Black_moons, Yes pictures please!!!!
            Rgds
            Michael
            Australia
              Neat! Aint it wonderful being able to make exactly what you need?
              Make it fit.
                Long ago I ground a 1/4" sq HSS cutter with a profile much like the parting tool insert only more exaggerated. I used it to cut over size grooves and I did a pulley groove once with it. I kept it perpendicular to the axis of the lathe and it worked very well. I went into the shop to look it up and take a picture and can't find it. I must have ground it to a different shape but I still think it is out there somewhere. I just can't believe I reshaped it for something else.
                I have used my insert parting tool like Bob did but I kept it perpendicular to the work and it did a fine job.
                  Like I said: A man who has a lathe and a mill doesn't have to put up with too much crap!!
                    Yes, he can make his own crap I mean stuff.
                      Bob,
                      One of my favourite cars, preferably a Hornet, but I once tried to buy a (yellow) '53 Super Wasp when I was younger, but couldn't quite afford it. The same car still turns up at events around Auckland...
                        Last time I did that I ended up with chatter marks. Now I've been using the compound.
                          Endquote:
                          No. Just do half and turn the pulley around on the arbor. Keep it closer
                          to the chuck.
                          ...lew...
                            Nice work Bob!
                            I have made many pulleys and used a similar method as you describe.
                            I ground this HSS tool to help eliminate chatter when cutting V's and grooving.
                            It works very good.
                              FOUND IT! but I see S_J_H posted his tool also. Here is the tool I made long ago.
                              I mostly used it for under cutting an area on a shaft but also used it for a pulley groove once. I couldn't believe I had discarded or reground it to another shape, I just don't do that and it's why I have a drawer full of all shapes of cutters.
