RPM's and feed speeds for drilling
  • RPM's and feed speeds for drilling
    I need to drill about one hundred holes in this angle table I am building. I need to drill 10.2 mm holes to tap to 12mm 1.75. The holes are going through 30mm plate. I will drill the holes on my horizontal mill.
    Any suggestions as to feeds and speeds.
    No.
    But I suggest that you drill 10.5mm instead of 10.2mm before tapping. It should hold plenty, and it's easier to tap.
    Thomas
    Problems worthy of attack prove their worth by hitting back
    - Piet Hein
      I would think that it would have as much to do with the bit chosen as anything else...?... and the grade of plate
        +1..... same as for any other machining op, determined by dia, cutter material and work material.
        just make it something slower than RPM = 4*cutting speed/dia
          BF....I think this link should cover it for you
          http://store.curiousinventor.com/guides/drill_speed/
          Ernie (VE7ERN)
            I find this LINK useful
            john
            John
            I used to be indecisive. Now I'm not so sure , but I'm not a complete idiot - some bits are still missing
