Can anyone identify this machine?
  • Can anyone identify this machine?
    While in the process of getting some junk out of the basement of a house across the street, i came across this item. Can anyone advise what it could be used for and maybe who made it.
    thanks
    It looks like a truing jig. You would put a bar between centers and use and indicator to check how it runs. You could use it for balancing as well.
    KEJR
      It's a "bench center". Like mount a workpiece between centers and measure it for taper, roundness, etc.
      That one is ancient, maybe turn of the century Brown & Sharp.
        Hi,
        Looks like an old bench center. Used for inspection of shafts and such. You would place the parts between the centers and then you could easily measure things like out-of-roundness and diameters. They could also be used for what ever else a person could think up.
        dalee
          It is a set of bench centers For checking parts between center.
            Pretty much what KEJR and Lazlo said.
            Also used to straighten shafts that come out of heat treat prior to grinding.
            I am not quite sure how it is done as we farmed it out but shafts would come back quite straight and have a spot or two that looked like they had been hit by a torch flame. That way we wouldn't grind through the case hardening.
            By the way, Joe.
            Looks like you scored in the tool bit department too. Lots of special ground tool bits that will save you lots of hours on a bench or pedestal grinder.
            And with a little care, all that carbide tooling will last you for a long time.
            The collet closer is also a very handy feature. If you don't get a set of collets with it, you will want to get a set. Very handy.
              Send me a PM if you need help cleaning that kind of basements.
                If you clean it up a bit, it would be a very desirable item for someone who works on old Harley engines. It would be used for truing flywheels.
                  Why on earth would anyone true up a Harley flywheel?
                  Makes 'em sound more like a Honda.
                    So you're saying Hondas run like out of tune Harleys?
                      And who knows what it would do the the reliability!
                        I know it as a "Bench Steady" from the shops I have been in. It is used for checking concentricity or truing between centers.
                        K Liv
                          It could be a bench centers, as others have stated, but it's possibly the swivel top from a tool and cutter grinder's table. The nuts in the corners could be the T bolts for clamping in the T slots. Also bench centers, at least the ones I've seen, have a much thicker base.
                          Harry
                            Um, no.
                            I think you know what I'm saying.
                            HD has a design philosophy with which I do not agree. If you ride one, I'm OK with that as long as you acknowledge the limitations and don't attempt to misrepresent the machine as something it is not.
                              Harry
                              That's what I was thinking.
                              One end has a spring lever for retracting the center enough to remove the part. That's usually on grinder centers, but could be on bench centers also, of course.
