Accuracy of the Busy bee 10x18 B2227L lathe
  • Accuracy of the Busy bee 10x18 B2227L lathe
    ever wouder how good these machines are well here you go enjoy the video,
    here is the youtube link feel free to leave comments
    http://www.youtube.com/watch?v=IMC_G22SuCM
    Sorry but that procedure tells you nothing about the accuracy of the machine. About the only thing it is capable of showing is any none cyclical errors in the spindle bearings.
    Phil
        now thats funny as sh*T
          I couldn't watch the whole thing. He made assumptions that aren't true, and he had the indicator mounted poorly to make that measurement. I was about a half thou of runout, and probably with the angled mounting of the indicator stem it ended up showing less than there might be.
          If the runout I interpreted is roughly correct, it's no wonder he needed that many spring passes to 'clean up' the stub. He probably is more or less correct that the stub is now 'round'. After that many passes, all the high spots have been knocked off, and what's left is something smaller in diameter than you may have wanted, but probably fairly round.
          I looked at that lathe, but I didn't ask to hear it run. Now that I've heard it- hmm, that whine would drive me crazy, and the loose rocks sound would as well. I'm hoping that all gear head lathes aren't that noisy-
            Most of the gear heads I've heard are a much quieter than that lathe.
            Harry
              Probably decent for the money.
                Harry
                Until you get them loaded up.....with a few beers.
                As for the video, it's really funny. His not knowing if the lathe came from China or Taiwan (or even that it made a difference) got me started. His thinking that the runout on the cylinder he'd just done was a measure of the lathe's "accuracy" had me falling out of the chair. Thankfully, I was able to hit something that closed the video, or I'd probably have died laughing.
                  Hey, I resemble that remark!
                    What a plonker,if he's using a HSS tool bit,1520 rpm is a bit fast for that diameter.
                    Judging by the number of times he retracted the clock probe and let it flirt back into contact with the work I doubt the clocks any good for any accurate work,not that it would matter anyway if he sets it up like that.
                    Allan
                      Hey Its Christmastime------
                      I owe my success to those who took the time, and cared enough, to show me the proper way to do things. Kevin's video leaves more questions than answers.Lets look at what he has done so far, and suggest how he can do better, instead of just criticising. Regards and Happy Christmas to all David Powell.
                        the **** noise you hear is cause is the crapy mic on my camera, for one, 2 i have built pellet guns with this last amonge other stuff like axels , barrel mods, recrowing of barrels, many many differnt guns parts that have very tight tolerences that have had to be very percise and this lathe has no problem doing that sort of work at all, ,
                        if you knew how to make a percision part which sounds like you cant , then you would know that muilty passes for finel clean up to the exact percice sizing is required, oh did i say that ,am i sounding like a know it all again , dam you know you gota lot to learn yet i think,oh wait i know you gota lot to learn yet..
                        have a great day ,
                          have a great day ,
                          Tell me about it, those who think they know it all really piss off those of us who do.
                          "the ocean is the ultimate solution"
                            Can We have this thread locked before It gets any farther away from real machining than it is.
                              When measuring with a dial indicator, the probe has to be at exactly 90 degrees to the work.
                              This is the test chart that came with my lathe... All measurements are in mm. But provided what you own does what you want it does not matter what anyone else thinks..
                              Precision takes time.
