Involute cutter identification.
  • Involute cutter identification.
    Can you identify the pressure angle of an involute cutter from the DP and depth as marked?
    A No2 cutter, 12DP, depth marked as .1798 - I need a 20PA cutter.
    Monarch 10EE 1942
    'fraid not
    Probably not. Thet are usually either 14 1/2* or 20*
    This is how it is marked on the cutter:
    http://en.wikipedia.org/wiki/Milling...te_gear_cutter
      No....
      The DP (Diametral Pitch)is based on the diameter of the pitch circle and the No. identifies the range of gear teeth that the cutter is able to cut.
      if u do a search here for cutting gears u will see there's been considerable discussion on the topic.
      The PA determines the profile of the teeth based on the angle of contact of the meshing teeth. it usually says on the cutter what the PA, DP and No. is.
      I spent most of my money on women and booze, the rest I just wasted.
        Bugger
        The PA is not marked on the cutter. Is there no other way to tell?
        Monarch 10EE 1942
          Usually if they are not marked they are 14.5 degrees, but that's not 100%
            That one sounds like a 14.5 degree one, the full depth of a 14.5 degree tooth is 2.157/pitch, for 20 degrees it's 1.800/pitch.
            Joe
              Right-o, thanks. Saved me finding out the hard way
              Monarch 10EE 1942
                Pa = 14 1/2*
                Depth of cut for 14 1/2* PA = 2.157/DP = 2.157/12 = 0.1795"
                Depth of cut for 20* PA = 2.25/DP = 2.25/12 = 0.1875"
                The cutter PA is 14 1/2*
                  Okay, so who's right ? Optics Curmudgeon or Old Tiffie ?
                    Both,
                    Works out the same.
                    tiffie has just repeated what Joe said earlier.
                      Okay, color me stupid here, but 1.800/12 = .150 Not .1875. What am I missing here ?
                        Tiffie's got the right 20 degree number, I was looking at the stub tooth table on that one.
                        Joe
                          Nearly.
                          I can vouch that its (too?) easily done Joe.
                          I've caught myself nearly doing the same as you did several times.
                            Thanks to both of you. I really appreciate it. I have cut a few gears, but not many, using an involute cutter and a dividing head. I've even repaired a metric gear using an American cutter. My set-up probably wasn't correct, but it worked. So I was happy.
                            Another thing I was wondering is which is the most commonly used.....the 14.5 or the 20 degree PA ?
                              Up until the 60's, 14.5° was most common. Now, 20° is most common.
                              14.5° pressure angle will mesh quieter and with less vibration, but 20° PA has a stronger tooth.
