gat-gun
  • gat-gun
    You may have already seen it ,but theres a good video of a gattling gun being fired at www.machineguns.co.nz. The gun has a 700rd verticle drum,pretty neat.
    If it goes BANG, I want one!
    would like to have plans to build one. you would be labeled an extreme terrorist.
      If it ain't 45/70 (or one of several related calibers), it ain't no Gattling! On the other hand, 700 rounds of .22's are lot easier on the pocket that 700 rounds of 45/70 ... Hmmm ... OK, I changed my mind. I'll take three!
        Perfect, just send $9K US x 3 and they're yours...less carriage!
        <font face="Verdana, Arial" size="2">Originally posted by tonydacrow:
        Snip&gt;I'll take three![/B]</font>
          Is a 30mm version of this or is that called a Vulcan?
          Jerry
            Its too late now Toolmaker. Just looking at that video was enough. You should have thought of that before you openned this thread. Now you know too much, and you must be watched. You might as well relax and get prepared for your body cavity search. It will be worse for you if you resist.
            I wish I was kidding.
            [This message has been edited by SJorgensen (edited 12-21-2003).]
              In some ways we are less restricted here. I believe as a seal hunter my only restriction is that the velocity be greater than 1800 fps. I wonder if this unit can be built in 223 cal. ?
