Anyone ever make a Vault type door?
  • Anyone ever make a Vault type door?
    Hi all,
    looking to add a little pizzaz to the entance of shop area in the basement.
    The rest of the basement is finished nicley, and thought a door that looks kind of like the entance to a vault would be pretty slick!
    Anyone make anything like this before, or similar type of mechanism that would fit the mood?
    some type of gear wheels and sliders etc.
    Would love to see any pics.
    KJ
    Never made one, but now you have me thinking...
      Oh I have wanted to do that for Soooooo long! Of course I don't live in a great neighborhood either, well city actually, my city is ****, ok. I was just thinking about a big solid wood door, built with planks, 1.5" thick, three layers of solid Hickory, would be heavy as hell. Use a center knob, probably some big old machine crank on the outside, that would twist a wheel with four bars to lock in the center of all four edges. Polish it all up and leave it out in the open for all to admire. Use a regular dead bolt to lock the center wheel.
      James Kilroy
        This is way out there, but there are some really impressive doors and locking mechanisms in the "Harry Potter" films, if you get into that sort of thing.
          So what are you hiding from the misses .... pictures needed!
          Peter
            Sure I've only got mini gear from Griz but I'd LOVE to do something like this. I'd probably not be able to do it on my apartment door. But I'm sure I could find SOMEthing "suitable" :-)
            I'm actually really interested in simple lock mechanisms as well.
            Please yeah, any ideas or brainstorms...
            Proud machining permanoob since September 2010
              Autoclaves have a big wheel with numerous tapered slider bars to latch securely........they don't have to worry about being opened from the inside though.........guy could make it up out of 10 guage hollow inner for the workings should give the effect.......fire dept, building inspector, insurance co might not like it though........
              Opportunity knocks once, temptation leans on the doorbell.....
                Neat idea! I think the challenge is doing it affordably
                I've seen laboratory pressure chambers at the junkyard that have those spin locks -- you might just scrounge one intact, although they're pretty heavy.
                  I think he could lighten up the workings but the design is kind of similar to the vault door with pins.....wouldn't require anywhere near the number of pins also......I would make the inner door smaller dimensionally than the outer so you had a tapered fit also........just depends on how much "vault effect" your seeking.........LOL
                  12 guage is probably about as light as you could go if your going hollow.......could skin it out of lighter guage with a wood core but that type of lock mechanism would have to be all routered out beforehand.
                    And if you need info or pictures, I would suggest reading/asking at http://www.lockpicking101.com. Be sure to explain why are you asking vault photos/info, as it is deemed an advanced subject and public discussion of opening or related gets the topic locked.
                      Heres a link to a small door model......not really what I've encountered but it does have a vault door look.......
                      http://www.cnautoclave.com/index.php...p_image&pID=50
                      If that doesn't float your boat.......theres the drive through model.........
                      http://www.aschome.com/
                        With respect to locks, the old explosive magazines where I worked had locks requiring 2 large keys with 1/2 inch shafts. One had threads and a shoulder arrangement to move a mechanical block out of the dead bolt and the other looked like a large skeleton key that had to be turned 3 revolutions to get the dead bolt out of the latch in the door frame. The dead bolt was 1/2 X 2 barstock that I am sure was heat treated.
                          At my last place, I did a fill in under that balcony and built a substantial door for it. The door was a 2 X 4 frame, which was insulated and covered. Those rods slid into holes bored into the frame. It turned out that this was over kill..........it really was a good neighbourhood. Still going strong last time I was by there.
                            Here's a pre-made vault door: http://www.smithsecuritysafes.com/pages/vaultdoors.html
                            I have one of their gun safes and am quite happy with it.
                              Here is one I made for a freind. It is a work in process. We are still tring to figure out the best lock mechanism. One option would be house entry keylock. Other option is pirated parts from innexpensive HF digital safe using the solonoid and gravity.
                              http://images.harborfreight.com/manu...5999/45891.pdf
                              The first pic is the hinge. Used drill rod plug welded every other section inside of cut peices of DOM tube. Every other one welded to door. Works great.
                              First is outside of door, next 2 are of inside of door. Works pretty well but is a little stiff because of warpage from welding and reinforcing the door. 4 locking pins but could be expanded to lock top and bottom as well. $ locking pins but could be expanded to lock top and bottom.
