OT: Renaming a link
  • OT: Renaming a link
    Haven't done it in a while but for some reason it's not working for me now. For instance renaming www.plazamachinery.com to "look here" I get an error message.
    I have in the past typed "here" in reply, highlighted it and then copy/paste the plaza address in the insert link box.
    What's up? Running W7
    I bury my work
    I am assuming you want to be able to do something like a "click HERE" for the link kind of thing.
    To do that, you have to post the "left bracket", then "url=http://www.plazamachinery.com", then "right bracket", then the "HERE", then the "left bracket" again, the "/url", and close with the "right bracket".
    See if I did it right by clicking HERE.
      It should look like this:
      [url=http://www.plazamachinery.com]HERE[/url]
        Is this working
        So it is, thanks not how I did it before but will now
        I bury my work
          Look here.
          Still works for me using your original method, but I'm running XP.
            Go figure
            Originally posted by Highpower
            Look here.
            I am sure that worked for me in the past but something strange as it no longer does. I may just be making an error somehow but haven't found it.
            I bury my work
