Hey, Folks. Sorry about the newby question all over again, just a few days after one of the same variety. It takes time to sort out, settle down and become expert.
But here's a real one.
While going through the posts I came across the fact that MILL/DRILL of the Rong Fu bent, will float up and down due to gap-itis in the rack and pinion. I want/need a milling device and actually had that particular mill/drill in question on my list of potential prospects. But no more.
My question to you all is;
Is this tool floating a particular problem with all MILL/DRILLS in general or just with the Chinese/Taiwan connection?
There isn't much difference in price between the floor model MILL/DRILLSand a KNEE Mill so I made a "U" turn here and looked back a bit.
Will a MILL, such as the Enco 8" x 30" or Grizzly G3616 Vertical Mill 9 1/2" x 31 1/2" or a Jet mill have the same problem with the milling tools floating up and down. This doesn't seem logical to me that there would be very much "play" in the rack and pinion or you couldn't be very precise with your work.
Thanks for the input.
GreenWillyPeter at your service.
Leave the wild animals alone, their heads hurt after a busy night.
