Tool gloat
  • Tool gloat
    Can't beat the price....FREE!
    It's a Taiwanese "Dar Sin" 13x40. No idea of the age. Feels in very good shape....everything works smoothly with no play. The compound has about a full turn of backlash and the crossfeed seems like the screw might be bent....has a stiff spot on every revolution. I'mmhaving trouble reding the motor plate because they put it in a stupid spot. It appears to have a variable drive transmission, yet the motor says "variable speed 3 phase motor"...which seems dumb. I've got to see what I can source cheaper....a vfd or a single phase motor. Anyway, gonna clean
    It up and get it running in the next couple weeks hopefully. I'm looking forward to the upgrade from my old Clausing 4800
    Lathe
    Upgrade????
      Congrats. I hope it works well for you. Me, I would do everything in my power (no pun intended) to keep its 3-phase motor. Add a VFD or a an RPC, but to go to a single phase motor would be a big mistake.
      BTW, this is the lathe I got for free about 6 years back, also a Taiwanese make:
      It came with a crappy 3-jaw scroll chuck (.008" runout), but also with the working DRO, a Dorian D40CA QCTP, a No.2, No.4, No.7 and No.881 holders. About $1000 in rigging, shipping and repair parts to put it near-perfect. I think yours will be far less, unless you add a DRO and QCTP. Do remove the chuck key before applying power though.
        The Clausing is a lightweight, with only a 3/4 spindle bore and 1hp 110v. The new one has about 800 lbs on the old one. We'll see....i'll keep whichever one works better
          Your new one looks like it has a D1-3 spindle mount. Perhaps bigger? What's the through hole on the new one? The Victor is about 50mm through the spindle, 5 "Taiwanese HP" motor (really about 4.2), and speeds from 65 to 1800. It weighs 2600 pounds, so I felt safer using a rigger to bring it in with the right equipment and experience in doing it. I have since replaced the hardwood "pads" it's sitting on in the above photo and replaced them with steel pucks.
          How are you going to get yours of that wooden pallet safely?
            Here is someone talking about the same lathe
            http://www.greatlakes4x4.com/showthread.php?t=180641
              Lathe lookgs great, congrats! BTW is there a list I can get my name on to recieve a free lathe too?
              Gord
              http://gordsgarage.wordpress.com/
                Mine has 40mm spindle bore...which will come in handy. I've got a 4000lb engine crane to get it off the pallet. Had one of the truck drivers from work pick it up for me and drop it off....had a liftgate and a pallet jack...went surprisingly smooth
                  Gord
                  Man, do I wish there was a list like that. I need a CNC mill to replace/upgrade dad's Bridgeport for which we overpaid. I am getting close on an older Tree 325 with Bendix Delta Dynapath 20 control, just have to work out the barter.
                  I guess I shouldn't mention the Kent KGS-200 surface grinder I got for a half a Saturday of teaching a guy and his employee how to start-up and run his Citizen F12?
                  BTW lbhsbz, you can't be a hick. I've been to Long Beach, and that is about as "industrial" a beach as I have ever seen.
                    Proposal for 2 new Forum rules
                    New rule #1). Gloats with photos showing the chuck key in the chuck wont count as a gloat without a clear disclaimer. Otherwise "it never happened".
                    New rule #2). Asking the reason for new rule 1) will result in an instant and permanent ban from all machining related internet forums on the grounds that the transgressor lacks sufficient imagination to be capable of working safely and therefore should not be encouraged to continue.
                    Phil
                      Oh gimme a break. The lathe is strapped to a pallet, and I haven't even bought the VFD to make it run yet....the chuck key is stuck there because I couldn't think of a better place to put it for the time being. Once the lathe is operational, I'll put it on my little rack on the wall where I put chuck keys.
                      Did anyone looking at that picture really think the lathe was anywhere near operational???? Seriously?.....
                        Heh! Good one, Phil....
                        I'm sure you were jesting...
                        John M...your (un)usual basement dweller
                          It was a leg-pull with a serious note. You obviously didn't pick-up on either.
                          There is actually nothing in the photo to indicate that it is not operational. In any case, operational or not, it is just bad practice to use the chuck as a convenient place to leave the key. Trust me on this.
                          Phil
                            Welcome to the club! (the lathe-for-free-club)
                            It looks nice.
                            Free-Myford-lathe-owner (mine also had a bent cross slide screw when I got it )
                            Thomas
                            Problems worthy of attack prove their worth by hitting back
                            - Piet Hein
                              Did you replace it or straighten it?
                              I'm going to try and take it apart this weekend and straighten it. I'm more concerned with the full turn of backlash in the compound.
                              I called KBC this morning...as it appears from the link someone else posted up that they were the original distributors for the machine, and they said DAR SIN has been out of business for 15 years and there are no manuals, replacement parts, or anything left anywhere for this machine. Hm. Enco was of no help either.
