lathe bits?
  • lathe bits?
    Hello. I'm looking form some help identifying some tool blanks from my late step dad. I have the following
    Latrobe crusader XL
    Crucible REX 95
    Crucible CMP Rex T-15
    Anybody know what material these would work best on?
    I turn a bit of everything all as a hobby on a 11 inch Sheldon
    I have a Chinese bxa size QCTP and a lantern tool post with Armstrong holders.
    Thanks
    Jeremy
    All three are premium HSS tool blanks. They are very hard and perhaps better suited for fine feed finishes and hard and/or tough materials than roughing and heavy tock reduction.
      May I ask why? Are they too hard, and therefore brittle, and fracture easily ?
      Thomas
      Problems worthy of attack prove their worth by hitting back
      - Piet Hein
        http://www.latrobesteel.com/
        look under the "technical" drop down. Tons of information, a comparison of those products to start with but also data sheets on each individual one.
          All are high quality HSS that have few equals. I don't think the stuff you get now is as good as those older pieces. Use the current American and Import for most your turning and save those for the important jobs.
          I have a lot of the older stuff I save for special work.
            The T-15 is a high tungsten HSS that's really nice for abrasive work. Lasts a good while when other stuff wears away. Not a lot of fun to hand grind.
            The Rex-95 is a good steel as well. Holds an edge pretty well.
            I don't recognize the Latrobe but their stuff was top notch.
              Thanks to all for the great information. I appreciate it.
