Quick & dirty follow-rest.
  • Quick & dirty follow-rest.
    I needed 2 ft of 5/16" aluminum rod for a paying job and all I could find on a weekend was 3/8".
    I think it was Evan a while back that suggested this quickie solution for a similar problem and it worked well again. A piece of scrap angle iron and UHMW bolted to the carriage with a a hole drilled & reamed via the lathe chuck worked great! .375" down to .314" in one shot. I switched from carbide to sharp HSS after the pic because the carbide refused to cut down that far. Flex in the shaft I guess. After the cut, I filed & polished by hand for the final finish.
    I would have tried putting the follow on the "following" side of the cut.
    But what do I know, I've never done it. :-)
    ...lew...
      Hi,
      Putting the follow on the other side gets to be too far from the work area to be useful for holding the work steady. And it will leave marks on the finished side. Something you don't generally want.
      A good "in a pinch" solution Dickybird!
      dalee
        dalee
        So it isn't really a follow rest it is a leader rest, amateurs
        Fast and effective when used as directed
        Nice job, I'll have to try to remember that one.
          Originally posted by doctor demo
          ....amateurs
          Dangit! A feller can't get away with nuthin' around here.
            I wouldn't say "quick an dirty," but "quick and EASY."
            That one's going into my idea book right now. . .
            Frank Ford
            HomeShopTech
              Originally posted by DICKEYBIRD
              I think it was Evan
              Where does he post now?..
              Rob
                Holy cow, I'm going into Frank Ford's idea book!!!
                Surely I get some kinda lapel pin or merit badge or something!
                  Rob
                  Rob there was a post here a while back with a link to an astronomy board that Evan posts on. I miss him around here too.
                    Hi,
                    dalee
                    I don't follow that. I could put it just as close to the tool on the "following" side as the leading side and if the HDPE material scars a peice of aluminium I wonder about the aluminium. :-)
                    ...lew...
                      Looks good to me,and unlike the factory rests it can be put wherever it's needed.I like it!
                        Actually, this kind of rest exists in a slightly different format: with intechangeable bushings.
                        This one (tool holder/follow rest combo) has a screw in the back that moves the tool bit.
                        WI/IL border, USA
                          I kinda like the British term: 'traveling steady'. As opposed to: 'fixed steady'.
                          Don Young
                            ...lew...
                            Hi,
                            You could mount the bracket on the far side of the saddle. but then you would need to reach all the way across the saddle to the tool. This would tend to make for an awkward and clumsy setup.
                            Next thing is, you still need to support the work piece ahead of the cut zone. Supporting the work behind the cut will still allow it flex away from the tool.
                            And if you are spinning the piece as close to the proper speed as you can get, HDPE will leave marks on aluminum. Maybe it might not matter much if you file and then polish with sand paper. But if you need as round as possible, such options aren't always a choice.
                            dalee
