Pool Pump Motor
  • Pool Pump Motor
    I have a pool pump and motor, works fine. Any reason to not trash it? Uses?
    Its not even a spare, its totally different than the one on my pool. I got too much junk!!!
    Send it to me. I have a friend who needs one.
      They are pretty high speed, 3450 RPM usually, though some are two speed and there are some new ones that are full variable speed.
      Had one for a long time and never used it. Didnt have a lot of torque for what we needed.
        Heck no, don't throw it away! A friend gave me one with wallered out pump & motor shaft. I fixed the shaft, trashed the rest and made a buffer/polisher out of it. Cheap! (I love cheap.)
          I would say no because they are continuous duty motors and normally .75hp or larger.
            They tend to have non-standard shafts with threaded ends. If you want a pump, that's one thing, but as a general purpose motor, it gets harder to use them.
              If you decide to scrap it ask your scrap dealer if they have a better price for motors before throwing it in with your regular scrap.
              Cameron Watt: Welder, blacksmith, egotist.
                I may try this. Good idea!
                  A special end might be an issue, but I have a 1725 rpm TEFC motor that was a poolpump replacement which I am using on my air compressor. Regular shaft.
                  Cost me a big $5 new and unused...... the smaller motor is good for the compressor because it has to run from an inverter and battery solar setup in a shed. I turned down the pulley to compensate for less power.
                    I did a few seperate projects with them when I was in high school. One involved watering a rather remote piece of lawn using a pond as the water supply to avoid needing hundreds of feet of garden hose (the land owner had plenty of extension cord). The other (for same owner) was a homebrew water fountain for his lawn using the pump and a small nozzle to increase the pressure. Since you have the pump I say use it. Electric motors are a dime a dozen, so no use wasting a perfectly good pump.
                    Machinery related idea - how about using it to add coolant to a machine?
