Cam Action Clamp?
  • Cam Action Clamp?
    I need to make a locking device to hold a block onto a shaft, much like the way a quick change tool post mounts. I need to have it lock without threads. The clamp, if i remember correctly, has a wavy base with a piece that will lock it w/ less than 180 deg. of turn, much the way a qctp feels when the wedges or piston locks.
    Does anyone know how it is made or where I can find a drawing or other info.
    thanks
    ed
    Take a look at bicycle cam action seat post clamps. Some of the photos on EvilBay give enough detail that you should be able to work from them.
    David
    David Kaiser
    ― Robert A. Heinlein
      If this copies this is what I am looking for
      http://www.techno-isel.com/LMC/Produ...MLockClamp.jpg
        Not sure if this helps, but is it like a cam action edge clamp like in your link?
        http://www.valtrainc.com/WHTools/cac.htm
          Will a CAD file help any?
          http://www.reidsupply.com/Detail.aspx?itm=CAC-10
            Thanks for all the info. I actually made a test piece of alum. late this afternoon. Made it on the mill w/ rotary table and power down feed. I think I have the concept and will try to figure out the amount of slope/slant? tomorrow.
            thanks
            ed
