fairchild lathe poem the art of the lathe
  • fairchild lathe poem the art of the lathe
    Leonardo imagined the first one.
    The next was a pole lathe with a drive cord,
    illustrated in Plumier's L'art de tourner en perfection.
    Then Ramsden, Vauconson, the great Maudslay,
    his student Roberts, Fox, Clement, Whitworth.
    The long line of machinists to my left
    lean into their work, ungloved hands adjusting the calipers,
    tapping the bit lightly with their fingertips.
    Each man withdraws into his house of work:
    the rough cut, shearing of iron by tempered steel,
    blue-black threads lifting like locks of hair,
    then breaking over bevel and ridge.
    Oil and water splash over the whitening bit, hissing.
    The lathe on night-shift, moonlight silvering the bed-ways.
    The old man I apprenticed with, Roy Garcia,
    in silk shirt, khakis, and Florsheims. Cautious,
    almost delicate explanations and slow,
    shapely hand movements. Craft by repetition.
    Haig and Haig behind the tool chest.
    In Diderot's Encyclopaedia, an engraving
    of a small machine shop: forge and bellows in back,
    in the foreground a mandrel lathe turned by a boy.
    It is late afternoon, and the copper light leaking in
    from the street side of the shop just catches
    his elbow, calf, shoe. Taverns begin to crowd
    with workmen curling over their tankards,
    still hearing in the rattle of carriages over cobblestone
    the steady tap of the treadle,
    the gasp and heave of the bellows.
    The boy leaves the shop, cringing into the light,
    and digs the grime from his fingernails, blue
    from bruises. Walking home, he hears a clavier—
    Couperin, maybe, a Bach toccata—from a window overhead.
    Music, he thinks, the beautiful.
    Tavern doors open. Voices. Grab and hustle of the street.
    Cart wheels. The small room of his life. The darkening sky.
    I listen to the clunk-and-slide of the milling machine,
    Maudsley's art of clarity and precision: sculpture of poppet,
    saddle, jack screw, pawl, cone-pulley,
    the fit and mesh of gears, tooth in groove like interlaced fingers.
    I think of Mozart folding and unfolding his napkin
    as the notes sound in his head. The new machinist sings Patsy Cline,
    I Fall to Pieces. Sparrows bicker overhead.
    Screed of the grinder, the bandsaw's groan and wail.
    In his boredom the boy in Diderot
    studies again through the shop's open door
    the buttresses of Suger's cathedral
    and imagines the young Leonardo in his apprenticeship
    staring through the window at Brunelleschi's dome,
    solid yet miraculous, a resurrected body, floating above the city.
    Outside, a cowbird cries, flapping up from the pipe rack,
    the ruffling of wings like a quilt flung over a bed.
    Snow settles on the tops of cans, black rings in a white field.
    The stock, cut clean, gleams under lamplight.
    After work, I wade back through the silence of the shop:
    the lathes shut down, inert, like enormous animals in hibernation,
    red oil rags lying limp on the shoulders
    of machines, dust motes still climbing shafts
    of dawn light, hook and hoist chain lying desultory
    as an old drunk collapsed outside a bar,
    barn sparrows pecking on the shores of oil puddles—
    emptiness, wholeness; a cave, a cathedral.
    As morning light washes the walls of Florence,
    the boy Leonardo mixes paints in Verrocchio's shop
    and watches the new apprentice muddle
    the simple task of the Madonna's shawl.
    Leonardo whistles a canzone and imagines
    a lathe: the spindle, bit, and treadle, the gleam of brass.
    B H Fairchild
