ID this scraper
  • ID this scraper
    I just picked this scraper up for $38 at an auction. I have not had a chance to pull it apart, ( I will once I get home from work).
    Has anyone ever seen this kind before? If need be, I'll get some more pictures posted later.
    Eric Sanders in Brighton, Michigan
    www.scope-werks.com
    www.compufoil.com
    Here are some more pics. I took the front assembly off of the motor unit.
    Here is a shot with the guard removed. The scraper blade fit into the slot in the guard:
    Here is the blade drive unit. The big bearing is mounted at a slight angle, so it wobbles with a forward backward motion. The blade holder must ride against the forward edge of the bearing. There are witness marks on the edge of the bearing, but I can't tell if the holder had a thin bearing that rode against this, or perhaps oilite?
    www.scope-werks.com
    www.compufoil.com
      Dang, must have found a rare one!
      www.scope-werks.com
      www.compufoil.com
