D T I is this right?
  • D T I is this right?
    I bought a mitituyo dti on ebay it arrived the large needle works ok but the smal dial is set at 5 nos 1 to 5 and when the [plunger is depressed it goes backwards towards zero . through 5 to4 to3 to2 to1.This is reverse of what I'm used to seeing is this faulty looks to be perfect otherwise??? Alistair
    That indicator is from a Dial Bore Gauge, for measuring cylinders and bores.
      Hello Alistair, Knock, knock....it was made on the other side of the planet. On that side of the planet the dial goes the correct direction!!!!
        OK another point then on another mitutoyo dti where the numbers work fro 1 to 5 ok the number one on the small scale does not go all the way back to zero sits about halfway between 1 and 2 can this be regulated/reset.? Alistair
