Zone 3 taps??
  • Zone 3 taps??
    I've just been sorting through a box of ex-Ministry taps that I bought, noticed that a number of them are marked
    "**Whit Zone 3 HSS" (All are Goliath brand I think)
    What is Zone 3? Any clues? a grade of HSS, or a specific thread size tolerance? They look to be perfectly ordinary Whitworth taps, though I haven't tried measuring any. There was a bunch of Whit and UNC wire insert taps among them, but these are not insert taps.
    Thanks
    Tim
    Its the uk version of 48 short of a secret area
    IGMC
    Just south of Sudspumpwater UK
      zoning
      Zoning B.S 949/1951
      specified dims for taps there were 5 zones
      Zone 1 ground taps for precision class 3b
      Zone 2 ditto
      Zone 3 ground taps for commercial work medium fit class 2b
      Zone 4 ground taps used for machine nut taps
      Zone 5 cut thread taps
      from a CEJ booklet screwing taps and their uses
      Lee
      I no longer own tools I had.
        Originally posted by shadoof
        Zoning B.S 949/1951
        Zone 2 ditto
        Lee
        Thankyou.
        Bog standard taps, then
        Tim
          yep, bog standard.
          lee
            Here I thought it meant Chinese standard for the west, so that nothing would work right or could be disassembled so the great unlearned would run out and buy another, thereby guaranteeing Far East retirements.
            mark costello-Low speed steel
              Over here zones tell you when you can safely plant different things in the spring. We're in zone 7 so the zone 3 tap would have to go in much later than usual. I think for us it would mean count to four before you insert your tap. Dunno if I can wait that long.
                OK, ol' clueless here wants to know what the heck a wire insert tap is.
                  Helicoils
                  see http://www.emhart.com/brands/heli-coil
                  Steve Larner
