Length of Travel Solved.
  • Length of Travel Solved.
    I had trouble with my installation of a LMS Spring kit on my HF Mini-Mill. The instructions said to drill hole in column back at 12". It would not allow me to lower my head to reach table top surface. I calculated it should go another 2 1/2" or 14 1/2" on back side of column for the 23/64" hole for air springs bottom bolt. After calling Little Machine Shop who sold me the kit I was informed by Chris he was going to change that dimension to 14 1/2" on the drawing supplied with the instructions in the kit. I thank Chris and all of you who provided insite into my problem.
