Three days, and I'm tired of using my two 5/16" tools in the lathe that utterly dominates my workbench.
How to fix that? Drop the compound slide!
Yank it out, measure it, lop off most of the measurement in my mill, chuck it up in the four-jaw, measure the alignment pin to zero cut down on the rotational runout (+/-.0005), turn the dial indicator to measure the facial runout (within .002 across 4" or so), and...
Right. How to face off the part that's supposed to be holding your tool on the other axis?
To the scrap bin!
It's hardly ideal, but that cutter was surprisingly solid. And now I should be sized to use 1/2" tooling, perhaps even needing a little shimming on that. No problem there--I'll have an AXA toolpost soon as my next paycheck comes.
Now, I hope everything's still in spec. It's a pain getting any kind of decent surface finish on cast iron at a 150 RPM interrupted cut.
To the scrap bin!
