I am in desperate need of a few items and thought I would start a thread for my questions. So I have one localized place for answers.
First off I would like to purchase a few things and need some feed back.
Mill Vise. Opinions on this one?
Boring head.
What should I be looking for and avoiding. Would like to be able to bore up to 5 or six inches. Will mostly be doing holes 2" or less.
End mills.
I have quite a few smaller sizes but I would like a set. Preferably in a box.
I see Enco is advertising 20 double ended HSS end mill sets for less than $100. Good buy? Or avoid them.
Face mill for smaller surfacing jobs.
OR fly cutter?
Carbide insert tooling for lathe. Looking for something common and reasonably priced that can be used in a variety of holders. TPG? I have some TPG inserts and boring bars to hold them. I also have a fairly large supply of CNMG inserts and a right and left hand negative rake holders.
I don't want to break the bank here. I would just like to have some common tooling so I'm ready to go when something pops up. I do mostly farm equipment repair so milling will most likely be limited to keyways and lathe use will be mostly cutting down shafts to fit bearings.
My personal projects are another story. I like to design things and push the limits a bit so I have no clue what I'll need for tooling there. I do like to build shop equipment though. I'm young and I figure if I build/buy the tools now, I'll have a lifetime to use them.
Boring head.
End mills.
OR fly cutter?
